native Houdini volumes
  • native Houdini volumes
    Hello, on the Vray4houdini page of chaosgroup website we can read :
    VOLUME RENDERING
    Fast and accurate rendering of native Houdini volumes and OpenVDB caches.
    My english isn't 100% accurate, but for me it's mean that i can render fire and smoke like i do in Mantra or redshift. using the bgeo.sc cache files i' usually do not ?
    so, i create my fire and smoke with Pyro, i assign a material with Vray-phxShaderSim. in parameter i setup Houdini fire/smoke then i fill the Fields with the correct temperature density etc attributs.
    I'm trying to render .. nothing appear.
    I check in rendering parameters in OUT context. i see a probabilistic volumetrics, i try to see if if's change something but not.
    How to render native Houdini Volumes ? needs help. thanks you.
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    I'm trying to use vdb cache instead of bgeo.sc .something wrong happend.
Name:	Annotation 2019-12-16 114202.jpg
Name:	Annotation 2019-12-16 114331.jpg
    freelance 3D artist
    www.ghiom.com
      it's say only .aur is supported
      freelance 3D artist
      www.ghiom.com
        ok i find, i think.. it's simpler than i was think. i have to find now the good parameters to render the same thing we have in viewport .
Name:	Annotation 2019-12-16 124753.jpg
        freelance 3D artist
        www.ghiom.com
          physically Based = 0.9 in volume grid fire intensity is a good start.
          freelance 3D artist
          www.ghiom.com
            Hello ghiom3d , you can use houdini`s native File or FileCache SOPs to load vdbs. VolumeGrid Cache SOP works only with aur files /ChaosGroup Phoenix FD cache files/. Looks like we are forgotten to update the docs page.
            Georgy Chakarov | QA
            www.chaosgroup.com
            georgy.chakarov@chaosgroup.com
              thanks you chakarov looks like i can use the bgeo.sc cache right now instead of a vdb sequence.
              Physicaly Based set to 0 make it very bright.
              Physicaly Based set to 1 make it fully black.
              It's like opposite than what i see on documentation. and 1 > flame are black look like a error to me not ?
              inb doc we saw that physically 1 make it more bright than 0 and in my case it's inverted.
              Nightly from 14/12/19 on H18 18.0.318
              freelance 3D artist
              www.ghiom.com
                Hey, ghiom3d ,
                the Physically Based option expects real-world temperature values, so a good start would be to remap the heat or temperature field to values between e.g. 800 and 3000.
                For instance, using a Volume Wrangle, you could
                f@heat = 800 + fit(@heat, 0, 2, 0, 1200);
                This should give you the expected behavior.
                We're currently working on adding information guides on major features so such information is readily available.
                Cheers!
                gosho.genchev@chaosgroup.com
                  Hi thanks you Gosho.Genchev . DOn't know if it's the nightly build or i misunderstand something.
                  I add the volume wrangle node after my cache file. i change heat by flame because it's the name of my attribut in my case.
                  now it's look thousand times too much bright. so i put physically based at 1 and i see better my fire. but i loose the colors of the flame. it's very long to render, it's not nice.
                  In the doc, when we change physically based from 0 to 1 , we add a lot of power in the fire. HEre, it's not the case, we have a powerfull fir at 0 and many less one at 1.
                  freelance 3D artist
                  www.ghiom.com
