Houdini Bake tool: How to
  • Houdini Bake tool: How to
    Hi guys,
    Is there a way to bake normal maps, bump maps, displacement maps using the new bake tool ?
    chakarov has been looking into the baking-related functionality, he's out of office for a few days and I'm unable to give you a decent answer so please hang tight until he comes back!
    Cheers!
    gosho.genchev@chaosgroup.com
      Hello stevejjd
      you could use bumpnormal element to do this, or to select desired operator/s in "Custom Operator" group.
      current normals element is based on angle between geometry and camera, which in case of baking is 90degrees on Z axis, it will be changed to a world normals in one of the next nightlies.
      displacement maps
      Unfortunately there is no easy way to do this out of the box, but I am working on a scene where I will show an easy solution of this task. I will upload it later today or tomorrow.
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
        Hi stevejjd , displacement extract workflow will be available next week, because V-Ray BakerTool needs an update which will get into nightly builds next week
        www.chaosgroup.com
          Thanks for all the work. Looking forward to it.
            Hello again stevejjd , sorry for the delay, this is an example of how you can extract height map with V-Ray BakerTool, you will need last nightly build. Everything is explained in the hip file, but if you have any questions feel free to ask here. The example will be uploaded as a part of baking tutorial in the docs page with next update.
            Click image for larger version  Name:	ExtractDisplacement.viewport.png Views:	1 Size:	584.8 KB ID:	1064006Click image for larger version  Name:	ExtractDisplacement.wire.0001.jpg Views:	1 Size:	4.16 MB ID:	1064007Click image for larger version  Name:	ExtractDisplacement.0001.jpg Views:	1 Size:	2.38 MB ID:	1064008
            www.chaosgroup.com
              This is amazing. Thank you so much. Just incredible support here on Chaos Group forums.
