How do you work with RenderElements
  • How do you work with RenderElements
    Hello folks,
    I am interested in your workflow when you are setting up your RenderElements.
    The typical ImagePasses are available in the VRAY RenderChannelNode.
    How do you set up a fast setup for checking the typical passes (around 10) passes?
    Do you have some kind of presets for that? In Maya it's a matter of double-clicking on a pass, in Houdini it takes much longer.
    Any best practice?
    Thanks a lot
    Helge
    1. Have you checked the presets drop down?
    2. Have you tried creating a HDA and reuse it?
    Regarding 1 I'll double check if it's documented, but it's actually a collection of Python scripts and you could customize / add your own.
    andrei.izrantcev@chaos.com
    Support Request
      Hey pixeltrain ,
      there are a couple of presets under the Images -> Render Elements part of the UI - you can hit the Generate button to automatically hook up a network with those.
      You could also add your own presets, or make an OTL out of the render elements network.
      I suppose others could chip in with some suggestions as well.
      Best regards!
      gosho.genchev@chaosgroup.com
        Thanks,
        which preset drop-down do you mean, where can I find it?
        The HDA would be the next step.
        Thanks,
        Helge
          Ok, found the presets under Images -> Render Elements.
          How can I make my own Presets their?
          Thanks guys - really helpful!
            https://forums.chaosgroup.com/forum/...ion-glossiness
            Check sub-directly "vfh_home/templates/re", there are some python files, those files are used to build the menu ROP->Images->Render Elements->Templates.
            Create some use directory like "c:\home\vfh_user_home" and point VFH_USER_HOME env var to it, then create sub-directory structure "templates/re" there.
            Copy and rename some template file from "vfh_home/templates/re", edit it to create the nodes you need with names u want.
            Support Request
