how to load *vfbl file for hundreds rop render ?
  • how to load *vfbl file for hundreds rop render ?
    hello,
    i have many many rop render setup in my houdini file.
    this is design object that i have to render.
    I have setup a beautifull color corection and all with the VFB and save it as a *vfbl file.
    now i can apply this vfbl file to all render by starting an ipr of each one and loading the vfbl file..
    but i have hundreds or thousands rop.. i can't take that time !
    Do you know if there is a way to load the vfbl in all rop at a time ?
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    There is no built-in functionality for this, but you could copy VFB2 settings parameters with some script.
    For VFB2 we're storing settings at ROP string parameters "_vfb2_settings" and "_vfb2_layers".
    I guess you'll be interested in "_vfb2_layers" (for VFB1 we have "_vfb_settings" and "_vfb_settings_ext").
    Script may look smth like that: https://gist.github.com/bdancer/2ccf...2b8b4c1c497ae5
    andrei.izrantcev@chaos.com
    Support Request
      bdancer Hi, thanks you a lot, i'm not at all a script or dev man . So i think to understand what you mean and what script say. but where and how to use it it's another story
      freelance 3D artist
      www.ghiom.com
        1. Make a new shelf tool, copy and paste this script there.
        2. Select ROP nodes you want settings to be copied into, now select with shift-click the node you want to copy settings from - now press the shelf tool button we've created in step 1.
        3. Now if you render with any of the selected ROP nodes VFB2 layers should be as in from node.
        Support Request
          So easy when you know ! thanks you
          If i change the vfb2 layers of the source rop after this script. it's applied automaticly or i need to re run the script ?
          freelance 3D artist
          www.ghiom.com
            Need to re-run.
            Support Request
              Need to re-run.
              Thanks.. WOuld be great to add in vray ROP a load vfbl file to synch all rop we want without need of a script
              freelance 3D artist
              www.ghiom.com
                Hello bdancer , isn't working.
                What i do wrong ?
                First a select all the rop on the left (1) with a rectangle selection.
                Second, a shit click on the rop alone on the right ( 2 )
                Then, i hit the button i created in the shelf bar to start this script you give to me ( 3 )
                when i render the other rop , the layers are differents than the rop of step 2 .
                freelance 3D artist
                www.ghiom.com
                  I'm not quite sure you still have nodes selected... this is how it looks for me:
                  Support Request
                    bdancer yes that was like that before i reorganise the nodes to take the screen shot.
                    I will retry this later this week end.
                    freelance 3D artist
                    www.ghiom.com
