How to access Vray Asset Browser in Houdini
  • How to access Vray Asset Browser in Houdini
    Sorry for this question, maybe I am blind^^ but I wanted to try out the new material library with vray 5 but I cant find the asset browser in houdini. Or how do I have to acess it? I couldnt find anything in the help either. I installed vray just by pointing the env file to the newest nightly version.
    Jon
    Yeah, I found them not in the Material Palette but in the Tools.
    Open in your network view (/mat context) the Tools-Palette (top icons) and look for V-RAY Material Libary.
    Sceenhsot attached.
    Regards,
    Helge
      Hello Jon3D , new V-Ray material library is available only on windows for now. You can find materials in Material Palette tab. Be sure V-Ray is enabled in Edit > Preferences > Rendering menu.
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
        Thank you both for the quick help!
          Is there a way to download the asset library files for VFH somewhere manually? I did install vray only via the env file so I think I am missing the assets.
          The default path of the texture materials will fail therefore.
            Is that possible?
              Unfortunately no, there is no way so download material library manualy. The only way is to install V-Ray for 3dsmax of Houdini /on windows/.
              www.chaosgroup.com
