GPU TexBlendBumpNormal
  • GPU TexBlendBumpNormal
    Hey Team,
    I'd need to use the BlendBumpNormal node, but all the inputs are unavailable for GPU (CPU works fine) - supported feature list says it is available on GPU though.
    Any help appreciated.
    Thanks,
    Chris.
    I do not think is available in the GPU yet which is a pity. RS support this workflow. I hope Vray can get on it.
      Okay, we have a glitch in the manual then, I can live without it - would be much more easier though.
      https://docs.chaosgroup.com/display/...orted+Features
        Can we get this working on the GPU?
          BlendBumpNormal is still not available in GPU mode?
          I get all greyed out in this node when I'm in GPU mode.
          I thougt I can blend bump and normal maps connecting the bump map to vrayMtl node and then this to V-ray Bump material node with the normal on it but this is not wotking either.
          Any workaround to mix bump and normal maps in one material?​
          www.gaell.com
