Rendering lots of points with attributes
  • Rendering lots of points with attributes
    Is there currently a workflow that will let me cook points to an alembic and then render them as points without unpacking them?
    I am doing millions of bubbles with the foam shader. But I need velocity and pscale.
    Leaving them packed means I have no velocity or scale. but unpacking them means that they have to be written to vrscenes for rendering.
    This is kind of critical to be honest. We have a lot of shots like this coming up.
    PScale and v are accessed by the renderer at render time. You can't manipulate them after writing them to the alembic, but the renderer does use them. Usually I use the IPR with the geometry before writing alembic, and find good values, then write the alembic and render the frames.
    Hristo Velev
    MD/FX Lead, Bottleship VFX
    Sofia, Bulgaria
      Hrm. I tried the packed alembic but it just renders black. I needed to unpack it before it would render. Maybe I need to investigate closer. I wasn’t doing anything to it at all after unpacking. It is literally one alembic read node.
        Ok, I see where the problem is now. If I apply a standard VRay shader to my points, they render fine as a packed alembic.
        If I apply the foam shader I get nothing.
        Hope this helps!
          That's interesting, if the foam shader does anything that would cause it? The devs could shed some light on it
          Hristo Velev
          Sofia, Bulgaria
            That's not yet implemented...
            Could you pls send me a test setup so I could verify the upcoming implementation?
            andrei.izrantcev@chaos.com
            Support Request
              Sent you mail.
