H18 nightly
  • H18 nightly
    Isn't possible to have multiples materials in an object node with GPU ?
    I have a mesh with multiple part. Like a box withe all faces as separate mesh.
    Each face have different material.
    So, i setup for each face it's own group.
    I create a material node.
    I set this material node to " numbers of materials : 6 "
    I give all groupes a vray material.
    It's work only in CPU, on GPU only the first group have material.
    So, i use blast to separate each face.
    I add a material node to each face. So i have 6 materials node. each one is connected to a blast non selected.
    I add a merge to merge all thoose parts.
    It's work on CPU, not in GPU. Only the first one in merge node have material.
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    Looks like a regression, will fix asap.
    andrei.izrantcev@chaos.com
    Support Request
      Same issue here regarding materials, also Matte/Visibility object properties working only with CPU.
      Shall we continue to post H18 nightly issues or shall we wait with these bdancer ?
        miro.digital, both of those issues are not related to 18.x at all (and present in 17.x builds as well, and are not related to Houdini, but to V-Ray).
        Both are logged and will be fixed asap.
        Support Request
          K, thanks for the update!
