(fixed) [HOU-1844] Double geometry rendered when using wildcards and subnets in force objects
  • (fixed) [HOU-1844] Double geometry rendered when using wildcards and subnets in force objects
    Hi!
    When specifying a subnet and wildcards in force objects on the vray rop the objects inside appear to be rendered multiple times on top of each other.
    I found this when using SSS in alSurface.
    If I only specify the subnet name it renders fine. Like this: Click image for larger version  Name:	no_wildcards.png Views:	1 Size:	199.0 KB ID:	1068806
    But if I add wildcards it appears as if the same geo is rendered twice. Like this: Click image for larger version  Name:	with_wildcards.png Views:	1 Size:	221.6 KB ID:	1068807
    Attaching a simple scene showing the problem.
    doublegeo.zip
    vray version: Build number:6275 hash:c636f2f
    Thank you!
    Head of Lighting @ Goodbye Kansas Studios
    Hello Hannes Drossel , I've reproduced it and reported as HOU-1844. I will write back here once it is fixed, Thanks for the feedback.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Great! Thank you chakarov !
        Hello again Hannes Drossel , this seems to be fixed with last nightly build.
        www.chaosgroup.com
