Motion blur on changing topology alembic issue
  • Motion blur on changing topology alembic issue
    I'm enabling motion blur in my scene which has an animated alembic, and the animated alembic shows up just frozen on the last frame of animation. I ran a few tests and found that generating a motion vector pass causes this issue. Is there a way to disable non-camera motion blur on an object? Although it is animated, it's not moving much relative to the camera, so that could be a good workaround.
    If you want to use motion blur on object which has changing topology you should enable "velocity blur" under "Sampling" sub-tab of the Render tab of geo Node properties.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      That worked! Thank you chakarov!
