Not sure if that's an intended behavior or a bug, but when the vray ROP is set to Render Frame Range and I press the Render button in the Frame Buffer, it goes off and tries to render the entire sequence.
Is there a way to prevent that?
To mind mind it would make sense to render the full sequence only in batch mode or when you hit the Render to Disk on the ROP, rather than when I do test renders on the buffer.
thanks
thanks
