Instance shapes scaling randomly per frame
  • Instance shapes scaling randomly per frame
    Hello, I have a scene that has many instance geo on particles. I am attempting to render this on my render farm. when I send the vrscene creation to the farm and then the vray standalone render job I get a render that glitches on every frame with the geo scaling up and down per frame, as if pscale were randomized on every frame. However when I export the vrscene from my local workstation and send that to the renderfarm I get a stable render where there are no glitches. I have been looking into basic config stuff on my farm versus my workstation but I haven't been able to see any differences. I am using Houdini 18.5.351 with vray 50050 on windows 10. I am using Deadline as my farm manager.
    If anyone has any ideas on what this is, I would love to know. thanks
    Best, Christian
    That's something that could happen when V-Ray versions for the standalone and the local VFH mismatch - usually we assign the VFH version as a standalone, to make sure they match.
    Hristo Velev
    MD/FX Lead, Bottleship VFX
    Sofia, Bulgaria
      That was a great idea, I was running standalone instead of standalone from vfh. So I corrected that and ran another test render. Unfortunately, I got the same result. Another idea I had was to produce a vrscene file of the same frame locally and then from the render farm and run a diff on them. I ran the diff and there are differences between the two, specifically it seems with assigning meshes to the instances. I would love for someone at support to look at these files but they are too big to upload here.
      Thanks.
        What if you replace the alembics with boxes, will get small but the pscale would still be in effect.
        Hristo Velev
        Sofia, Bulgaria
          ok, the boxes worked fine, no glitches. The difference is that I am not using packed alembics. I am using internal referencing with the op: syntax. In my point wrangle I changed this snippet:
          int inst = int(rint(fit01(rand(@id), chi('Min"), chi("Max"))));
          "s@instancepath = sprintf("op:/obj/Dirt_Geo/OUT_DIRT%s", inst);"
          to this:
          "s@instancepath = sprintf("op:/obj/Dirt_Geo/OUT_BOX");
          Does this mean I should use packed alembics of my geo instead? I am trying to feed four or so variations of the geo on my particles.
          Thanks.
          best, Christian
            Yes packed alembics work great for standalone rendering
            Hristo Velev
            Sofia, Bulgaria
              I tried this with packed alembics and I got the same result.
              so I had an idea to see if the geo was scaling or swapping on every frame.
              I assigned different colors to each and did a test render and found that
              the geo was swapping and not actually scaling. I am deleting the particles after
              they reach a certain height so I know the particle numbers are changing, which is why
              I made sure to use the @id for the random assignment as this should not change after
              particles are reaped (or that is my understanding). So, as a workaround I scaled the particles
              down to 0 instead of deleting them so that I could retain particle numbers. I did a test render with
              this and the render came out fine, no glitches.
              The box example worked because I was not assigning different types of geo to the particles.
              So, having said all that, I am not totally sure why @id works when I do a local scene export and why
              it does not work when I send the exporting to my renderfarm. Could this be a bug? I double checked to make sure that
              @id was not changing and did animation previews before sending and everything looked good. I also noticed that vrscene files
              make note whether or not the scene is being exported interactive or not, so maybe that's a factor too, I am not sure.
              I am using an instance SOP with a point wrangle to assign geo to the particles.
              I know you are pretty experienced with this workflow so I am hoping with this new information you might have some idea
              of what's going on here.
              Thanks.
              Best, Christian
                You can mimic the different shapes by having a box and a sphere, and see how it works. If you post a scene or a screenshot at least it would tell the story better - not sure how exactly you're doing it, and there's so many options
                Hristo Velev
                Sofia, Bulgaria
