*SOLARIS* aspect ratio differs
  • *SOLARIS* aspect ratio differs
    when dropping down a rendersettings node the aspect ratio for vray doesnt match karma and opengl.
    Click image for larger version  Name:	karma_aspectratio.png Views:	0 Size:	563.8 KB ID:	1134602Click image for larger version  Name:	vray_aspectratio.png Views:	0 Size:	541.8 KB ID:	1134603
    Click image for larger version  Name:	aspectratio.png Views:	0 Size:	83.7 KB ID:	1134604
    V-Ray for Houdini number:18151 hash:6d37533 from 13 Dec 2021 03:28 (build number:18151)
    V-Ray Core 5.20.02 [58987b7e] from 2 Dec 2021
    http://goodbyekansasstudios.com/
    V-Ray renders whatever resolution Hydra gives it.
    This is not reproducing for me all the time and restart delegate seems to fix it every time so I could consider it Solaris issue and I'll check with SideFX if we could do smth about this on our side and they should fix this somehow.
    andrei.izrantcev@chaos.com
    Support Request
      for me it is reproduced everytime but i realised there is some settings that isnt getting picked up by vray
      *aspect ratio conform policy*, if i change this to crop aperture i get the same results. To be honest im not sure exactl what this means
      also data crop window and aspect ratio arent supported, but maybe we are supposed to set those on the vray tab?
Name:	aspect _ratio.png
        This look same as vray bug with viewport render and camera
          I've also no idea what does this setting do and how it is exposed as Hydra property.
          Could it be that togging this setting just updates the resolution to the correct one in Hydra?
          DmitriiP, no, it's not, the topic is about Solaris and V-Ray USD Hydra Delegate.
          Support Request
            vray "ignore" (aspect ratio) of clipping area of viewport if cam enabled and height of cam higher then clipping area both in region render & solaris.
              if i reversed the resolution so its 2000 pixels in height and 200 in width it breaks with crop and works with expand. just wanted to tell you
              about data window for settings overscan and aspect ratio are with setting them on rendersetting also the standard tab or somewhere else?
Name:	data window.png
                Click image for larger version  Name:	_ss1.jpg Views:	0 Size:	413.7 KB ID:	1134631
                Click image for larger version  Name:	_ss2.jpg Views:	0 Size:	586.9 KB ID:	1134632
                Click image for larger version  Name:	_ss3.jpg Views:	0 Size:	376.4 KB ID:	1134633
                everything lower by HEIGHT then 1920x1021.28 will render as expected
                  camera Aspect ratio 1920x80 vs 1920x2080
                  aspectratio2camsHip_and_screenrecord.zip
