TexBerconGrad vs TexGradRamp
  • TexBerconGrad vs TexGradRamp
    Hi!
    While I was trying to replicate a uv pass using TexGradRamp I've seen that this texture doesn't outputs a linear gradient and in comp it was a mess. Then I found that TexBerconGrad does that perfectly well and the linear gradient output works just fine in comp using it as a stmap.
    Is this an expected behaviour in the TexGradRamp?
    www.gaell.com
    Can't reproduce it on my side. By default V-Ray Gradient Ramp produces linear gradient. May be some of your gradient points has non-linear interpolation type. If not, than a hip file will be appreciated.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Could be to the fact that I'm working on ACES?
      www.gaell.com
        No, my gradient points are all linear.
        www.gaell.com
