Custom aovs don't work with packed alembics.
  • Custom aovs don't work with packed alembics.
    Hi there.
    In our current build ( '52020', '0598092' ) customs aovs (e.g. texture plugged into the material output aov_1) don't work with packed alembics. Unpacking the alembic makes it work but isn't really an option as it increases vrscene generation times.
    In a newer build '52020', '8c7bc47' this seems to be fixed already but I cant upgrade currently due to mismatches between how the 'remaps' behave/misbehave.
    Is there any other 'trick/hack/workaround' that you know of apart from unpacking the geometry in SOPs?
    Martin
    > Is there any other 'trick/hack/workaround' that you know of apart from unpacking the geometry in SOPs?.
    The workaround is to restore previous behavior for remap... Pls, try the tomorrow nightly build.
    If this still won't work a .hip file will be helpful.
    andrei.izrantcev@chaos.com
    Support Request
      Hi bdancer
      Unsure which thread I should be posting this in now and I am starting to lose overview a bit but we have downloaded the following build “52020”, “023ec12” and now colour ramps are broken which again means I can't use the build.
      Did you want me to use a specific build?
      See screenshots below. A grid, a noise, feeding into a float to colour remap. Expected result is colourful.
      See network as well as vray version on the two screenshots.
      Hip file also provided but probably not necessary.
