V-Ray for Houdini number:23911 hash:a62975a from 13 Apr 2022 19:08
V-Ray Core 5.20.20 [18a43118] from 12 Apr 2022
Good morning,
I have a texturing issue: the bump map channel in the V-Ray Material isn't receiving input data when I'm using a triplanar node with rest attributes. Everything works fine until I switch on the rest attributes in the object properties (image 2). After switching this on (for the whole session, even if subsequently turned off), the image input only works in the bump channel if not using a triplanar (compare image 3 and 4). This is only the case for the bump map channel - I can still plug the triplanar into other channels, e.g. diffuse, and it works (image 5).
Hope that's clear. Let me know if you need anything else.
Good morning,
