(Fixed) [HOU-3220] Crowd Randomize Clip Time Issue
  • (Fixed) [HOU-3220] Crowd Randomize Clip Time Issue
    Hi, I have trouble with houdini crowd clip time. I use Houdini 19.0.561 and vray 5.20.02.
    I made simple crowd scene using crowd source.
    I only set randomize agent primivites and randomize clip time. I set randomize agnet primivies 5 agents using simple FBX for test(mocapbiped and mix amo)
    If I set randomize clip time on and random clip offset 3 or so( more than 0) , render result is fine(See firset attahment pic),
    but if I set random clip time on and random clip offset 0 , render result is strange(see sedond attachment pic). at this case,
    randomize agent primitives is not effective.
    Is this vray bug? and Can you fix? THanks
    Hey kazuyori_kosaka ,
    A couple of things that would help us resolve the issue for you:
    1. Under the top menu bar -> V-Ray -> About V-Ray -> Copy to Clipboard button -- could you please paste the information here so we know the V-Ray version and exact build that you are using?
    2. If possible - the scene file + the FBX file - you could also send it through the support system instead of uploading it here for everyone else.
    I'll also check on my end - we have test scenes with agents that haven't shown issues but it's possible a specific combination of paramters causes trouble.
    I'll keep you posted!
    gosho.genchev@chaosgroup.com
      Hi Gosho
      Thanks for reply!
      1. I pasted below
      V-Ray for Houdini number:23914 hash:a62975a from 13 Apr 2022 19:17
      V-Ray Core 5.20.20 [18a43118] from 12 Apr 2022
      2. I want to send files through support system.
      Can you send link support system?
        Hi Gosho
        I cleaned up scene, and upload here.
        Using FBX file is mixamo"s file .I wrote character and animation at sticky note of hip file, you use same one from mixamo.
        I use checker texture from download one, so you use appropriate checker texture .
        thanks
          hi @Gosho.Genchev
          Do you have any progress about this problem?
            Dear kazuyori_kosaka, hello.
            As mentioned also in the ticket, the issue is now logged in our bug tracking system for further investigation.
            Thank you for the provided files. The second archive contains all that we needed.
            TS
            3D Support | contact us
              Hello again,
              The fix is implemented in our latest nightly builds.
              I have just answered you via the opened ticket too.
              Please check are you able to see the folder as described.
              Waiting for your answer.
