(Open, Open) [HOU-3217] [HOU-3218] Displacement for Instances Bug?
  • (Open, Open) [HOU-3217] [HOU-3218] Displacement for Instances Bug?
    Hello!
    My render freezes/crashes when I add displacement to my Instances. Maybe I do it the wrong way or it's a bug.
    sometimes it works but slow and when I stop the render and start it again it freezes. IPR seams to render somehow but production has it's problems.
    I use Houdini Indie 19.0.622 and V-Ray for Houdini number:22079 hash:b86215f from 15 Jun 2022 01:34
    V-Ray Core 5.20.20 [b929ba03] from 8 Jun 2022
    Here's the Scene:
    https://we.tl/t-6VjnQyMH7V
    Cheers
    Tobias
    Anyone having the same problem?
      I'll look into this asap.
      andrei.izrantcev@chaos.com
      Support Request
        Hey tobiasroesli ,
        The problem seems to be related to the Rayserver Instancer option on the V-Ray Object Properties. I'm sure Andrei will fix it as soon as he can - meanwhile you could disable Rayserver Instancer as a workaround.
        Best regards!
        gosho.genchev@chaosgroup.com
          Hi Gosho.Genchev ,
          thanks for the workaround, I'll stick to it.
          Cheers!
            Hello Gosho.Genchev ,
            I found another bug which is related to the Use Rayserver.
            There's also a connection with it and triplaner normal maps.
            https://we.tl/t-wev6tD0GtK
            Cheers!
              Hey tobiasroesli ,
              Thanks for the heads up! Just to confirm - the issue that you have is that the projection appears different when you enable "Use Rayserver Instancer", correct?
              Thanks!
                yes, when I disable the Rayserver on all blocks are normal maps appearing/working. When I enable it, they disappear on a few blocks/sides. Looks like that they work in some angles but in others not.
                Cheers!
                  Great, thanks for confirming!
                  All the best!
                    Hi Gosho.Genchev ,
                    I got another Question. I was wondering how to make Instances of an object which has a Displacement applied? I pack the object and after I apply a material which contains the Displacement.
                    Now when I render it compiles all the instances displacement seperated which means one object needs 300 MB Ram for Displacement and 10 3000 MB. How can I avoid that. So it only compiles for one object and then they are instanced.
                    Do you know what I mean?
                    Best
                    Tobias
