"Direct Illumination" on V-Ray LightMtl and RTX/CUDA
  • "Direct Illumination" on V-Ray LightMtl and RTX/CUDA
    The "Direct Illumination" option on the V-RayLight Material don't seem to have any effect(renders material black) when using the RTX or the CUDA engine.
    It seems to work fine on the CPU engine.
    (vray_adv_60021_houdini19.5.435)
    Seems to work on my end. Is this the official V-Ray 6 build ? Can you share simple scene?
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Yes it's a offical V-Ray 6 build, however the issue was due to the geometry being (Packed Alembic), which the CPU engine/mode supports but not the RTX/CUDA engines.
      Also noticed that the "Direct Illumination" option on the material only works if the material is assigned directly on a geometry node in the "Objects" context, not if the shader is assigned inside a geometry node. But there are workarounds for both situations of course...
