GPU RTX Error
  • GPU RTX Error
    I'm getting some errors when rendering in GPU RTX mode. CPU and CUDA are fine.
    I also get the errors with an old alembic which used to work 3 month ago
    This is the error:
    [12:02:13.338] Warning : Checking CUDA driver version: 5001: Installed driver version (566.36) is newer than the latest verified one (566.14)!
    [12:02:13.468] Error : [VUtils::VOptix::AccelerationStructure::buildAsync] 7900: OptiX error encountered in vray_optix7.cpp[2070]. Error Code 7900
    [12:02:13.559] Error : [RTOpenCL_impl::validate] 1: Abort was requested.
    [12:02:13.559] Warning : Cancelling GPU rendering!
    I'll send you the files via chaos support.
    I use Houdini 20.0.896 on Windows 10.
    V-Ray for Houdini number:22828 hash:deecb26 from 07 Jan 2025 00:56
    V-Ray Core 6.20.25 [c690129c] from 3 Jan 2025
    Dear tobiasroesli, hello.
    As I wrote you in the ticket ( # 335894 ), the scene is rendering fine in our environment.
    About the GPU drivers - please take a look at this post: https://forums.chaos.com/forum/v-ray...ws#post1224560, where our V-Ray GPU specialist is sharing the recommended ones.
    And the whole topic is dedicated to the recommended installation ways.
    Waiting for your answer.
    TS
    3D Support | contact us
      Hi tsvetomira.girginova ,
      thanks for the test
      I installed the recommended 566.14 Studio driver but I have still the same error...
      I also did a test with a different pc: Ryzen 5950x & RTX 4090. But same problems.
      Looks like I have to render this Project with CUDA.
      Cheers
      Tobias
        A little update for lost 3D Artists with the same Problem:
        tsvetomira.girginova wrote me:
        since the issue that you are facing is related to RTX only, may I ask you to try even older GPU driver version?
        Recently we have contacted NVIDIA for a different issue, but again related to RTX performance.
        We have encountered that driver version 552.44 works well for these RTX issues.​
        This solved the problem for me and I'm now able again to use GPU-RTX
          Thank you for confirming, Tobias!
          We will add your scene for test purposes and inform you when we have green light from NVIDIA for a stable RTX performance with newer driver versions.
          Glad to help!
            Thanks a lot for the help! Appreciate it!
