[HOU-4656] Primary Visibility Off for Houdini Hair on GPU ignored
  • [HOU-4656] Primary Visibility Off for Houdini Hair on GPU ignored
    i am rendering houdini hair with VRay on the GPU. I can't render with the primary visibility set to off for the hair. It is just always visible. It works on the CPU
    Test scene is attached.
    Houdini 20.0.445
    VRay 6.20.25 22833
    Click image for larger version  Name:	cpu.jpg Views:	26 Size:	105.4 KB ID:	1226212
    Click image for larger version  Name:	gpu.jpg Views:	15 Size:	159.1 KB ID:	1226213
    Click image for larger version  Name:	rop.jpg Views:	15 Size:	36.0 KB ID:	1226214
    Hi CerpinTaxt Thank you for letting us know! We have this logged into our system [HOU-4656] and will be looking into it.
      Hi CerpinTaxt The issue should be fixed in the latest Nightly build. Feel free to download and test it: https://nightlies.chaos.com/main#/vray7houdini/nightly
        Hi Viktor, thank you for looking into it. Is it possible to get access to the vray 7 nightlies for houdini? I can only see vray 6 for houdini and vray 7 for all the other packages.
          Please, give me the email you would like the access to be granted to.
            So, I got access to the vray 7 nightlies and tried build 22887 from Feb 19th. Seems like the problem with the primary visibility on the gpu is still there.
            In addition to that I can't render point attributes from the hair on the gpu like e.g. rest, curveu. That also works on the cpu
ID:	1227689Click image for larger version
              Yeah Houdini/Maya this functionality isnt working, reading custom attributes in GPU and RTX
