Hello I'm trying to render a scene where the background is set to matte with shadows (see the first attached picture).
This works fine if I leave "Ordered Render Vars" blank on my Render Product node.
In this case, I get some default passes such as "color" and "depth".
However, I would also like some additional render vars, like Cryptomatte.
As soon as I start adding entries to the "Ordered Render Vars" parameter, the default passes disappear.
In the "Vray Standard Render Vars", under the LPE tab, there's an entry called "Beauty", with the light path expression "C.*".
Unfortunately, this does not work correctly with my matte object (see second picture).
How do I enable the default "color" pass while using render vars?
