Using <tex> and custom attributes in texture path
  • Using <tex> and custom attributes in texture path
    I'm trying to use <tex> in the filepath of my vray MetaImageFile node to grab a texture path stored as a string primvar on the rendered geometry, but am not having any luck. I've tried with the string stored as a regular usd attr as well. Is the following <tex> workflow supported in Solaris?
    V-Ray supports custom attributes in the File parameter, provided the attribute is specified either on the Geometry node itself, or placed on individual packed primitives. You can modify the File path with a custom string attribute "s@tex" with the following notation: "$HIP/texture_000<tex>.jpg".
    When using this workflow, be sure to force V-Ray to export the attribute from the V-Ray Object Properties of the rendered object.
    Thanks!
    Not yet.
    andrei.izrantcev@chaos.com
    Support Request
      Thanks bdancer , is that something we can expect in the next Vray Solaris update, or farther down the road map?
        Looks like something that USD/Solaris would take care of, when/if we switch to MaterialX
        Hristo Velev
        MD/FX Lead, Bottleship VFX
        Sofia, Bulgaria
          Yes.
          Well, no, there is no magic here... Such handling still will need to be implemented...
          Support Request
            Good to know, thanks!
            Hristo Velev
            Sofia, Bulgaria
              Bitmap path tags support is already in the nightlies.
              Support Request
                That's amazing, thank you!
                  bdancer Do you have an example hip of this working? I've got a string primvar: "primvars:tex" on the geometry with a texture path, but am having problem getting the shader to read it. In the filepath I've tried <tex>, <primvars:tex>. Should that work?
                  I'm using vray build 5.20.20
                  Houdini 19.0.498
                    > Should that work?
                    Yes, attaching example.
                    There is Top Menu -> V-Ray -> About with the build information.
                    Support Request
                      Thanks for the example. Turns out we were loading an older vray build.
                        Hi, i cant get this working in SOLARIS in houdini 19.5.493, ive got vray version 5.20.24. I think i understand what im meant to be doing with the <tex> in the path, and a attribute on the prims like your example scene, but sure its not working for me in solaris. tried every combination of doing it for last few hours. no luck. could we get a new example scene for new houdini version and/or a tip as to if its a bug or not? ive tried sopCreate, and also setting it up in obj context with material applied from mat context, and using SceneImport to get it into LOPS. no luck either. hopefully im being dumb.
                        Cheers
                        J
                          The provided example .hip file works fine for me. Could you share your .hip file that doesn't work?
                          Support Request
                            sure. attached here with test textures too. renders black for me.
                            • #15
                              ideally want the sop create method to work. appreciate your help Bdancer.
