I'm trying to use <tex> in the filepath of my vray MetaImageFile node to grab a texture path stored as a string primvar on the rendered geometry, but am not having any luck. I've tried with the string stored as a regular usd attr as well. Is the following <tex> workflow supported in Solaris?
V-Ray supports custom attributes in the File parameter, provided the attribute is specified either on the Geometry node itself, or placed on individual packed primitives. You can modify the File path with a custom string attribute "s@tex" with the following notation: "$HIP/texture_000<tex>.jpg".
When using this workflow, be sure to force V-Ray to export the attribute from the V-Ray Object Properties of the rendered object.
Thanks!
Thanks!
