Husk expecting QT when previously enabled VFB experimental
  • Husk expecting QT when previously enabled VFB experimental
    if you previously enabled the VFB option "Show VFB for Husk" in the rendersettings LOP, but then disable it - it is ignored when saving out the USD for later husk rendering.
    In the USD file there is still the flag set to "5" which leads to errors "No qt platform available"...
    I am referring to this line in the USD file:
    it is still saying:
    custom int vray:vfb:show_vfb = 5
    but should be after disabling:
    custom int vray:vfb:show_vfb = 0
    Could you look into that? Hope it was clear
    Thanks and cheers
    Dominik
    Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
    We do not write UDS files, Solaris does it, you'll have to figure our why it doesn't write the correct value.
    UPDATE:
    Oh, ok I see, this is a fake attribute to trigger showing VFB from "Show VFB" button.
    It shouldn't be taken into account for husk for sure.​
    UPDATE:
    This param is not taken into account if VFB settings are not enabled. Could you pls send me the hip/usd files?
    Is vray:vfb:settings_dir set?
    Is vray:vfb:show_in_batch set? It's basically the main control that enabled VFB for husk.
    andrei.izrantcev@chaos.com
    Support Request
