Experimental VFB settings in Solaris
  • Experimental VFB settings in Solaris
    I noticed there is a section on the render lop "vray>output>experimental" that seems to suggest we can render to the VFB in Solaris. Is this something that is functional by default, or do I need to set anything extra to get it to work? When I click "Show VFB" nothing happens, with no errors or output in the console. Just curious, as using the VFB to view and inspect local renders would be amazing.
    On Windows using H19.5.435 and V-Ray Core 6.00.21 [d833c431] from 9 Feb 2023​
    Thanks,
    Chris
    Have you tried starting viewport rendering? It should pop-up; check for messages in Houdini console for errors.
    It will only work if viewport rendering is already started.
    andrei.izrantcev@chaos.com
    Support Request
      Ah, that was it, thank you.
