(done) [HOU-1943] Let me give names to each layer
  • (done) [HOU-1943] Let me give names to each layer
    This is getting trick with a lot of layer in the layer texture, can I have the option to name each layer.
    Click image for larger version  Name:	layerText.JPG Views:	81 Size:	29.4 KB ID:	1073140
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
    This would also be useful in the blend Material.
    Best,
    David.
      This is a brilliant idea honestly!!
      I struggle with this a lot, and keep disconnecting layers or play with the mask to know which one is which.
      +1 for this
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        Would something along those lines work for you guys ? // those will update when you re-wire a socket, of course.
        Click image for larger version  Name:	tex_layered_names.png Views:	0 Size:	187.7 KB ID:	1073322
        gosho.genchev@chaosgroup.com
          That a cool option for sure, but the inputs might change several times, you add an additional curve, or color correct, clamp. So you then have to rename that new node to what you wanted.
          i would still prefer a name field to put what I want and that that would stay no matter what you connect.
          Maybe both options
          Also, wait a bit longer and see what more people say.
          Best,
          David.
            Oh, I didn't realize you want to actually write things down manually (and maybe I got a bit excited when I finally figured out how to add event callbacks to nodes ).
            Alright, will message back soon with something else.
            Cheers!
              heh
              You can keep in, it's very good info.
              Best,
              David.
                Hey!
                Thanks Gosho for the update, the workflow you showed is very helpful. I will need to rename if I add a clamp or curve like what David explained.
                If it is possible to do the naming directly to the the layered texture/Blend material that would be the best/easiest workflow
                If not, I can live with what you showed above.
                Best,
                Muhammed
                Muhammed Hamed
                chaos.com
                  Hi guys , Layer Name parameter is now available for TexLayered.
                  Georgy Chakarov | QA
                  www.chaosgroup.com
                  georgy.chakarov@chaosgroup.com
                    Thanks, chakarov and Gosho.Genchev, that's great ​news ​​​​​​
                      Really cool!
                      Testing this out now, works nicely
                      Cheers guys!
                      Muhammed Hamed
                      chaos.com
