Hi people, i had an idea for a long time to make thread like this so no1 should search around the forum for mel/py scripts to speed up the work, so here it is
this will be my 1st script/tool that would help u all coz it helped me 1000x
Vray Proxy Replacer
Note:
- you can select one or more proxy's and apply changes
- If the path field is empty the script will update only the check box changes (Bounding box, Show whole mesh, etc...)
- If the path field is not empty then the script will update the path for proxy file (leaving the original name of proxy file) + the check box changes (Bounding box, Show whole mesh, etc...)
If u find any bugs or errors let me know, and also if u have an ideas what i could change or add also let me know...
cheers
Vray Proxy Replacer
Note:
cheers
