is it possible yet, to dock the main VFB in to Maya's main window. Instead of the floating window?
We had this with Qt 4, but had to remove the feature when Maya switched to Qt 5 because it caused some issues. We should look into it again and see if we can fix it.
Would definitely free up some scree real-estate, and keep from having to keep moving the VFB to get to other windows.
Nikolay, the Maya Render View pops up and disappears when I render off a V-Ray render in the VFB.
I can doc a Render View in one of the windows, but how do you then get the render view to render and IPR V-Ray?
Hm.. here is what I am doing. I set V-Ray as a Renderer in the Render settings and turn off the "Use V-Ray VFB" option. Then I dock the Render view and finally I use its render icons to start either normal or IPR render:
