Bercon textures
  • Bercon textures
    Just tried the Create a VRay node from file>BerconTileTex nodes but not getting any results.
    I simply attached BerconTileTex to the color node but nothing, not even BerconNoiseTex or BerconWoodTex
    Is there a specific workflow?
    since the BerconTile is a custom plugin from 3DsMax it doesn't have the appropriate scale values as defaults suitable for Maya (one of the reasons why it is inside the plugins folder). You can try the following:
    On a new scene create a Plane and attach a VRayMtl with a BerconTileTex in the diffuse. Change the Size to a lower value from 25 to 0.025 and the Edge Color to white. This should give you some results. Check the attached image for a reference.
    Ivan Shaykov
    chaos.com
      I've attached some maya presets with some decent looking settings for various noises. Some of the numbers are super wonky and took a lot of experimentation to figure out. Extract them to your C:\Users\<username>Documents\maya\<version>\preset s\attrPresets\VRayPluginNodeTex folder
        The latest Substance Maya plugin could be a good alternative.
        Here at 16min. https://vimeo.com/355551799
        They show the Arnold workflow but it does work great with Vray.
        https://linktr.ee/cg_oglu
        Ryzen 5950, Geforce 3060, 128GB ram
          Thanks for sharing! I recall having a hard time dialing in the values when first time trying the bercon textures in Maya following a Max tutorial.
          always curious...
            It would be nice to have a proper AETemplate for some of these compatibility plugins so we can actually make good use of them. Right now it's just a jumble of unorganized attributes with bad default values.
            __
            https://surfaceimperfections.com/
              We are working on this.
                That's great to hear, thanks Vlado. I'm tired of the bad default noise in Maya, looking forward to getting some more options.
                __
                  Agree...
                  btw good few of Bercon Noise properties are not supported at all such as distortion, some of the noise types etc. - which often forces me to use Maya Simpex noise node.
                  Now when I think about it BerconMaps are one of the things I miss the most from 3ds max
                  My Artstation
                  Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
                  Sun Tsu
                    Originally posted by Karol.Osinski View Post
                    Agree...
                    Support for Bercon maps as native Maya nodes will be available in our next official release.
                    V-Ray for Maya dev team lead
                      Mihail.Djurev You guys are amazing! Great news! thanks
                      My Artstation
                      Sun Tsu
                        Any chance of a tip on how to plug a 2d texture node into the new VrayBerconNoise texture? I can't seem to find a way, and although I can move and rotate the texture in the UVW Generator Parameters of it, the appearance of it in the perspective view of Maya doesn't seem to match the render. Specifically, the Transform Angle on a Bercon texture I'm using doesn't match the render :/.
                          Can you give us an example? What texture are you plugging where?
                          Alex Yolov
                          Product Manager
                          V-Ray for Maya, Chaos Player
                          www.chaos.com
