Vray Objects Properties and Attributes
  • Vray Objects Properties and Attributes
    Are there any plans to add those Attributes per default to Maya Objects like Arnold or Renderman is doing?
    Every time you need to trun on some attributes per scripting you have to create the attributes first.
    It also does not work great with the new RenderSetup in Maya. Cause you cant override what isnt there.
    Is there any reason why Vray does handle it this way?
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    The way that Arnold and Renderman do this was implemented in Maya long after we had already implemented the V-Ray object properties; so far there hasn't been a compelling reason to change it. However if it's a workflow that is convenient for other users, we could consider it for sure.
      Thats a good point. Looks like im the only one.
      Thanks for the info Vlado.
