SSS in the vrayMtl broken?
  • SSS in the vrayMtl broken?
    Is the ss in the vrayMtl broken?
    It does nothing here.
    Im rendering with CPU on Vray5
    Here is the scene file.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    You need to add some refraction to the material so that the translucency is visible. Note that the fog color will be visible as well, so you may need to tone it with a darker color to see dominant sub-surface scattering in the result; the effect is stored in the refraction render element.
      Is there something about this workflow in the Vray Documentation?
        I tried it now. But its hard to balance those attributes.
        Im back to the ALSurface.
          I've never found the SSS attributes on the Vray material to be any use, ever. If you want a truly subsurface material, use the SSS shader.
            I was hoping that in Vray 5 we get the same feature with the translucency like in 3ds Max. There is a work around in Maya. Do not use the normal VRayMtl use a Vray Plugin node "BRDFVRayMtl" instead (Create -> V-Ray -> Create From V-Ray plugin -> BRDF material.
            We are using this for all our plants. I really would like the know the reason why the VRay material is different to the one in 3ds Max, even in VRay 5?
              Hello ! This is only my opinion !
              you don’t need use it because in the last beta of VRay 5 you have the new SSS + Thin Walled + 2SidesMtl you can check my test here:
ID:	1115631Click image for larger version
ID:	1115632Click image for larger version
              Carlos Alvarez Velazquez
              Tutorials about VRay for Maya:
              https://youtube.com/CarlosAlvarezVelazquez
                Here the resultS
ID:	1115635Click image for larger version
ID:	1115636Click image for larger version
                  Here other test with SSS + Thin Walled
                  ​​​​​​https://www.instagram.com/p/COx_qeSI_vs/
                    this isnt supported in GPU is it?
                    e: info@adriandenne.com
                    w: www.adriandenne.com
                      the new SSS is hidden the GPU UI, looks like this is gonna take a while
                      Muhammed Hamed
                      V-Ray GPU product specialist
                      chaos.com
                        No, it's not yet supported on the GPU. But we're working on it.
                        Alex Yolov
                        Product Manager
                        V-Ray for Maya, Chaos Player
                        www.chaos.com
