V-ray distance problem
  • V-ray distance problem
    Hi Guys,
    I am having some problems with the v-ray distance tex.
    Here is what is happening i am trying to mimic a max workflow when using the distance texture.
    I was trying to mimic adam martin workflow, something really simple. He plugged a texture on the distance texture atribute.
    Click image for larger version  Name:	Capturar.JPG Views:	0 Size:	138.8 KB ID:	1091063
    In maya i tried to do something similar beacause we dont have a input where we can input a texture in the distance and still input a value for the distance and change both at the same time as we do in max.
    So what i did was that i used a layered texture and in the first layer a i was just input the numerical value for the distance in the texture slot of the layer (changing the value slot).
    In the second layer i was plugging a texture and selecting the add blending mode but the result was affecting the whole radius of the distance. I never was abble to get the same result.
    Click image for larger version  Name:	unknown.png Views:	0 Size:	122.7 KB ID:	1091064
    Thanks Guys
    I'll see if we can do something about this. Try plugging the Layered Tex (you may use a Ramp to set up a vignetting effect) in the Near Color slot; this will allow you to control the diameter through the distance value.
      I use te ramp inside the layered texture? Or after the distance node?
        Inside the Layered Texture so as to get a similar to the mapped distance tex (in 3ds Max) vignetting effect.
          Hi Aleksandar!
          This is what happens when i plug the ramp in the near color slot!
          Do you have any other idea?
            Simply put your splatter texture in the Near Color slot. The mentioned ramp was just an additional process for finetuning.
              Hi hermit! i was never abble to make this work. To day i was trying to do something similiar in the radius slot of the vray dirt and got a similar result! You were able to find a way around this?
                I am struggling with the Vray DistanceTexture in Maya for a while, trying to achive the same results, as shown in Maya Distance Texture Help (or what is shownin many MAX turtorials). MAX has got in its Vray Distance Texture Help demo scenes.
                Can I kindly ask, please, for making a showing Maya demo scene, where it is working, as shown in the Help ? I mean a texture working in Distance slot, creating ripples around objects made by Ramp texture in Near Color slot. The only result, what I was able to achive, were ripples in the center of the pPlane, but not along the objects.
                  martin_weiss Check this thread. Note that the Ramp must be V Ramp. For circular - VRayDistanceTex's Red channel should go to both U an V.
                    Thank you hermit.crab very much ! You made my day!
                      i'm not sure if this is what you are looking for
                      You can connect any bitmap to the distance texture channel
                      and control the distance amount with the file´s alpha gain channel value
                        Thanks Aleks, that was a very helpful scene file.Perhaps the docs can explain better in the future
                        https://www.artstation.com/damaggio
                          Yes, we've already added info about it.
