Sit geometry on top of a Displaced surface
  • Sit geometry on top of a Displaced surface
    Hi all
    What’s the best way to sit scattered, placed and instanced rocks and grass on displaced geometry.
    I’m using a VRayDisplacement node for ground rocks and now want to scatter geometry which will sit on top of the displaced surface.
    Cheers
    Im not sure what u are using to scatter but I believe vrayacatterformaya allows you to load a displacement into the scatter and it shifts the scattered objects accordingly.
      I think I tried the same with Maya MASH some time ago and it didn't work. I didn't find a solution actually.
        Cheers for the info.
        I'm using Mash too.
        Current workaround is to use a Texture Deformer on a second piece of Geometry and roughly match the V-Ray Displacement.
        Paint using MASH Placer etc.
        Then hide the Deformed Geo from Primary viz etc
        Rendering the V-Ray Displacement and Mash Instances only.
        Shame there's no way to sit geometry on top of V-Rays displacement like in vrayacatterformaya.
          sweet jesus I hope this isnt the workflow....it makes world building very slow. Im currently trying to create a complex ground with scatting in areas on displaced ground, and maps for placement. so far Ive found UVW random breaks placement, but I cant seem to get the scatter geo onto the displaced surface either.
          Website
          https://mangobeard.com/
          Behance
          https://www.behance.net/seandunderdale
