Phoenix Ocean not rendering in vrscene
    does the vrscene I sent render fine at your end?
      Yes, at this point it renders correctly.
      Here are my steps in the order I made them:
      - installing V-Ray 5 for Maya 2020;
      - installing Phoenix FD 4 for V-Ray 5;
      - saving a .vrscene from Maya 2020 with "Use V-Ray VFB" disabled;
      - navigating to C:\Program Files\Autodesk\Maya2020\vray\bin and starting the cmd;
      - here is the command I'm using to start the render: vray -sceneFile="c:\temp\my_file.vrscene" -imgFile="c:\temp\render.png".
      Are your steps the same as mine? Could you try using my steps in the same order I made them and send us over the whole log from the Standalone's console?
      Thanks!
      Slavina Nikolova
      QA Specialist, V-Ray for SketchUp | V-Ray for Rhino | Phoenix
      Chaos
        OK so I just tried your steps and I still couldnt get the ocean to render.
        My steps are:
        1. Open vray standalone command prompt.
        2. using vray -sceneFile="D:\Projects\2020\AUT_11121_Boat\VRay\ho useboat.vrscene" -display=1
        This saves out a file same as your method without displacement.
        Click image for larger version  Name:	render.png Views:	0 Size:	611.5 KB ID:	1098564
        This is the same scene from within Maya VFB
        Click image for larger version  Name:	Maya render.png Views:	0 Size:	1.11 MB ID:	1098565
          P.S. There is no gap in the file name "houseboat.vrscene" I couldnt for some reason close the gap in the text in the thread above!!??
          vray command log.txt
            OK you have solved this issue!
            The clue was in your change directory, I had it set to "C:\Program Files\Autodesk\Maya2018\vray\bin>"
            When I changed the directory to "C:\Program Files\Autodesk\Maya2020\vray\bin>"
            All worked.
            • #21
              Hey,
              As I can see from the log, you are starting the Standalone's console using Maya 2018 and V-Ray 4.
              To be sure that you are using the correct vray.exe (as far as I understood you want to use Maya 2020) navigate to: C:\Program Files\Autodesk\Maya2020\vray\bin. When you are there write "cmd" in the Address Bar of the File Explorer and press Enter.
              Then type in: vray -sceneFile="c:\temp\my_file.vrscene" -imgFile="c:\temp\render.png", and the render should have an Ocean Texture.
              Hope this helps!
              Slavina Nikolova
              Chaos
