does the vrscene I sent render fine at your end?
Phoenix Ocean not rendering in vrscene
Yes, at this point it renders correctly.
Here are my steps in the order I made them:
- installing V-Ray 5 for Maya 2020;
- installing Phoenix FD 4 for V-Ray 5;
- saving a .vrscene from Maya 2020 with "Use V-Ray VFB" disabled;
- navigating to C:\Program Files\Autodesk\Maya2020\vray\bin and starting the cmd;
- here is the command I'm using to start the render: vray -sceneFile="c:\temp\my_file.vrscene" -imgFile="c:\temp\render.png".
Are your steps the same as mine? Could you try using my steps in the same order I made them and send us over the whole log from the Standalone's console?
Thanks!Slavina Nikolova
Phoenix QA Specialist
Chaos
OK so I just tried your steps and I still couldnt get the ocean to render.
My steps are:
1. Open vray standalone command prompt.
2. using vray -sceneFile="D:\Projects\2020\AUT_11121_Boat\VRay\ho useboat.vrscene" -display=1
This saves out a file same as your method without displacement.
This is the same scene from within Maya VFB
Hey,
As I can see from the log, you are starting the Standalone's console using Maya 2018 and V-Ray 4.
To be sure that you are using the correct vray.exe (as far as I understood you want to use Maya 2020) navigate to: C:\Program Files\Autodesk\Maya2020\vray\bin. When you are there write "cmd" in the Address Bar of the File Explorer and press Enter.
Then type in: vray -sceneFile="c:\temp\my_file.vrscene" -imgFile="c:\temp\render.png", and the render should have an Ocean Texture.
Hope this helps!
Slavina Nikolova
Chaos
