DistanceTex to mix different shaders/materials
  • DistanceTex to mix different shaders/materials
    I couldn't find any solution to this - other than compositing in AfterEffects: Is it possible to "blend" two shaders/materials with the distanceTex utility? How?
    Thanks for any ideas.
    A VRayBlendMtl with VRayDistanceTex as a mask (black and white far and near colors) for the coat shader should work. Or maybe I'm misunderstanding?
      Hi Hermit,
      Thanks for answering. Plugin into the Blend Amount did work.
      Is there a way to control the size of the blend area like sharpness of the blend?. let's say area with sharp edges.
      Current Example: A pipe shows two different shaders controlled by 90° plane that is connected to the distanceTex and moves along the pipe.
      If I use a cube instead of the pipe I get two areas, and not a single wider one with sharp edges.
        Example: Pipe and Controller Plane
Name:	Bildschirmfoto 2023-01-19 um 09.52.11.png
          You sharpen the colors by using the inside/outside solid options in the VRay Distance Tex. Check the attached scene.
            I got it - Thank you very much.
              Hi Aleks, I wanted to try your scene but is not a file that can be opened with 7Zip archive, nothing gets extracted.
              Is there another format you can upload?.
              Thanks
              https://www.artstation.com/damaggio
                Thanks
                It was archived via 7Zip. Try opening it manually (right click > 7Zip > Open archive). If that doesn't work, PM me your e-mail so I cant send it.
                  Cool, now it opened Aleks, thank you
