A way to previs the Vray water node
  • A way to previs the Vray water node
    Is there a way to render off a viewport playblast to show the rate and wave shapes? I cant seem to get anything to show up in the viewport, and the only option to test the speed of the node is to render a sequence...and thats not super efficient.
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
    For viewport I would recommend Boss,so you can see the waves, also Vray water node is not good for oceans, however it would work for a pool or lake.
    https://www.artstation.com/damaggio
      Im using vray water for a pond. Ive ended up switching back to just using the Maya Pond fluid option. Allows me to see whats actually going on in terms of animation in the viewport.
      Website
      Behance
        I agree. BOSS is better. You can get some pretty good result with that
          Just watched some BOSS videos...will defo see if thats a better way to create simple water stuff.....I did get the results I needed from the maya fluid pond option.
          Website
          Behance
            Does the Vray water node when plugged into displacement animate in IPR render mode? Is it just me....I cant get it to update, and in the user docs it says nothing needs to be animated to create waves. When changing frames, I see no wave movement...without seeing any feedback in the viewport, or in IPR, its very hard to look dev using this. I have no idea how fast things are moving without doing full blown render tests which is super inefficient.
            Website
            Behance
