AgX setup
  • AgX setup
    Am i setting this up correctly? I'm getting a widely different result with AgX than ACES.
    This first image is ACES, second is AgX.
    Click image for larger version  Name:	ACES_01.png Views:	0 Size:	1.98 MB ID:	1192439
    Click image for larger version  Name:	AgX_01.png Views:	0 Size:	2.06 MB ID:	1192441
    HI, thanks for posting. How did you set up Maya's colour space. Did you make any changes here:
    Vladimir Krastev | chaos.com
      I set i with an env var just as you would with Aces. Is that wrong?
        Are you sure the results you are getting are not expected? From what I've just read there is expected difference between the look of AGX and ACES.
        What about the display device and view transform? You've set them to "Display P3". What are the available options?
          this is modified ocio config from Troy James Sobotka. this one has an additional lut to match AgX Punchy look closer to ACES sRGB ODT:
          edit:
Name:	Screenshot 2023-10-05 204841.jpg
          Click image for larger version  Name:	Screenshot 2023-10-05 203840.jpg Views:	0 Size:	19.2 KB ID:	1192618
          Marcin Piotrowski
          youtube
            Thanks! I’ll try this tomorrow
              Works great. Thank you again
                ocio config for testing:
                https://forums.chaos.com/forum/chaos...89#post1195589
                acescg+acesrgc+agx
                Marcin Piotrowski
                youtube
