This seems like an obvious question, but is there a way to load an image sequence into the background of the frame buffer so when I move the play head in my maya scene the image gets updated with the correct frame? The maya native image plane has issues when the VFB is involved.
Vray Frame Buffer background image frame sequence
Originally posted by cgdom View PostYes, but the image plane seems to have issues with acescg exr's while sending a png or light jpg sequence to the vfb from the maya image plane creates color issues.
It does with exr's but did not seem to work with the PNG's or JPG's regardless of the color transform I pick in the file read node.
My initial question was about the VFB supporting image sequence advancing for it's background image layer which sounds like a no. If there are any vray devs here maybe put this on the list? Sort of embarrassing to have a render viewer that can't sync with the timeline of the host application.
Actually, you can do it with the Background layer by replacing the frame number with <frameNum>. It was in the docs all along.
- Likes 1
Tks so much!
