Light Instancing V-Ray Scatter
  • Light Instancing V-Ray Scatter
    Does anybody know if there is a tutorial to create scatter effects like the one shown in the help documentation?
    HI, this image shows the new feature of the Chaos Scatter, the ability to scatter lights. I am not sure how exactly it was made but by looking at it it seems like a lot of very small lights scattered with random translation.
    Here is a small scene showing the light scattering:
    There is also this short video showing the build process of the image you referenced. The lights scatter is not shown though. - https://www.youtube.com/shorts/22BO7uTbbx8
    Vladimir Krastev | chaos.com
      Thanks Vladimir. I will take a look.
        is it possible to get lights scattered with Chaos Scatter work with LightMix's instanced lights mode?
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          It works with LightMix's instanced lights mode. In the example below I have two Chaos Scatters, each scattering a VRayLight. The lights are copies, one is red, one is blue. The LightMix groups them in the same way as instanced lights.
ID:	1209812 Click image for larger version
ID:	1209813 Click image for larger version
            ok - sorry - I obviously missed the fact this is Maya thread.
            in my case (3dsMax) scattered lights are saved into Rest VRayLightSelect (created automatically by VRayLightMix) when the original light is on a hidden layer. all works as expected if original light is visible.
            I'm also one hotfix behind - might be relevant here.
            Marcin Piotrowski
            youtube
            CGI OCIO config 04
              Hi, I tried a 3ds Max scene as well. Again the scattered lights work with the lightmix
              Here I have two scatters and a dome light. As you can see they switch on and off properly.
                does it still work like that when the original lights is on a hidden layer? or do scattered lights go to “rest” layer in than case?
                Marcin Piotrowski
                youtube
                CGI OCIO config 04
                  I am not sure what is your setup exactly. I tried to move the light in a separate layer and turned it off. Light MIx still works and nothing is visible in the rest layer.
                    thank you for testin this - it must be my previous hotfix causing issues then.
                    much appreciated.
                    Marcin Piotrowski
                    youtube
                    CGI OCIO config 04
