Apply linear deformer to proxy
  • Apply linear deformer to proxy
    Hi folks.
    I cant seem to get this to work so would be good to see if anyone else can see whats happening.
    I have created a proxy using the old proxy import method..
    Change the preview to maya mesh
    Add a linear bend deformer and this seems to break the proxy and cant be rendered.
    I need to be able to put a little wobble on some proxy plants but this is preventing me from doing so.
    Im using the Indoor Plant 010 in cosmos.
    Is there a work around?
    I can't seem to reproduce this. Using the same VRay Cosmos asset and following your steps. Also don't you mean "nonlinear" deform? I'm using the latest official V-Ray build.
      OK here is a video showing whats happening
      https://drive.google.com/file/d/11lY...usp=drive_link
      Maya 2024
      V-Ray 6 for Maya, update 2
      (v6.20.02, revision 32557 from Apr 18 2024)
        Ok, I figured it out. Turns out the Deformer messes up the Material IDs of the VRayProxy (they reset to 1); otherwise, they render fine. I've logged the issue (internal bug-tracker id: VMAYA-13061) for dev investigation. Not sure if there's an easy workaroud.
