AO with GPU
  • AO with GPU
    Is there a work around to producing an AO dirt pass with GPU or do we have to just render twice?
    What is not working with GPU?
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
      Extra texture dirt pass. doesn't render in GPU.
        Its working if you turn off "as inclusive set"
          Oglu, I could kiss you. How did I not know this? Yep working fine now. Thanks for the VRay tip of the year...
            PS did you manage to get VRay 7 build yet?
              No Vray7 yet.
              I had the same AO problem a year ago.
                Could you explain this workflow a bit further? VRayExtraTex seems to work with GPU and VRay Dirt out of the box for me:
                Vladimir Krastev | chaos.com
                  Maybe different for MAX but for Maya it doesnt work without turning off "As Inclusive Set".
                    Sorry I overlooked this important point that this is actually the Maya forum. Apologies again and thanks for the reply.
                      No worries Vladimir, So would this be a bug then?
                      I couldnt find anything about it in the docs.
                        There is something going on. The default setup does not work with V-Ray GPU. I had to disable the "as inclusive set" like you mentioned. I will dig more into this and get back to you.
                          stezza This is a known issue in the GPU team. They are working to fix it and have made good progress. We will notify you the fix is ready.
