non consecutive frame sequence
  • non consecutive frame sequence
    Hi
    I'm wondering if its possible to specify a frame sequence in a coma separated list.
    For example: (2,34,128,133,99)
    If it's not possible I woul like to fill a feature request
    Thanks.
    Pablo.
    www.elranchito.es
    that would be a handy feature. Or handy to know how to do.
      I've noted this as a feature request; btw, if you render through the standalone, then you can specify any number of separate frames or frame ranges to be rendered in one go.
        You are talking about an external .csv list correct? Yes, that would be a handy feature. The last time I copy and pasted a long string of .csv values into a backburner project, I discovered that it flags an error after too many values have been typed in - I forget the exact amount. I ended up breaking the string apart into a dozen smaller chunks and sending multiple render jobs - all in an effort to correct the bad frames created from a jacked up server node.
        It's too bad Backburner doesn't do what it says it can and create an actual .csv version of the log. I ended up having to use Excel to manipulate and reorder the field data just to isolate the missing frames and republish them in a .csv format to then be copy and pasted back into Max.
          I dont use Backburner. I can use the standalone though.
          This is what I wanted. I hadn't realised that it could be done with the standalone version vlado.
          Thanks.
