Clear resin plastic toy shader
  • Clear resin plastic toy shader
    Hey!
    I'm working on a new toy that I will have rapid prototyped and then cast into resin toys, and I am using Vray to test the various colorways I want to be doing. One of them is a clearn resin/plastic like the picture below, often used in Japanese toys:
    Does anyone have any tips on how to create a shader like this? What's the best place to start? SSS materials?
    Any help would be highly appreciated
    /Bard
    www.hellobard.com
    Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
    do u have bigger image?
      Yep! I do!
      here:
      http://www.flickr.com/photos/3429560...7612580918361/
      aaaand
      there's some more toys in his flickr set:
      obviously the opaque parts have been airbrushed with paint, but it's the plastic i'm after.
      thanks bazuka! ^-^
      /Bard
      www.hellobard.com
        here's the original pic in hi-res:
        /Bard
        www.hellobard.com
          nice, if the shader i post doesnt work for u, ill make a new one, based on this pic
            thanks bazuka! i'll give the one you made a shot! I think it should work reasonably well. I'll post the results asap
            /Bard
            www.hellobard.com
              weeeell, it's not too bad, but it doesn't quite seem like a plastic toy... :/
              The japanese toys are rotocasted, so they consist of a 3-5 mm thick skin making the toy hollow. Both my 3d model and the actual 3d print will have a massive core. So obviously it's hard to get the same effect from the start when there are these sort of differences... :/
              /Bard
              www.hellobard.com
                To get the same kind of light falloff in the material, you really need to model it like a shell, and then use some glossy refraction and fog in VRayMtl to get that effect.
                  Yeah that was what I was thinking too, modelling-wise...
                  The actual physical model of the toy will have a massive core, so I'm better off trying to simulate that look in Vray instead. I'll throw some fog and glossy refraction on it though.
                  Thanks Vlado!
                  /Bard
                  www.hellobard.com
                    yo man, did u manage to make a shell toy?
                      hey bazuka!
                      yeah, well, the thing is, the toy will actually not be a shell when I make it in real life, so it's not necessary to model it like that for me. I'll just be doing test-renders with the shader you made. thanks for the help bazuka!
                      /Bard
                      www.hellobard.com
                        nice, can u drop some pics so we can see
