Hello,
I'm wondering if any of you have been using the nightly builds in production. I'm smitten with all these new features, but concerned about stability and compatibility in moving forward with them. I've been testing the one from 02/24, for example, and so far it seems stable and backward compatible with older (non-nightly) V-Ray installs, even when the file has been saved using the nightly build.
I also wanted to ask about "[feature request] Hide Maya render window, while rendering in VFB - resolved." How does one turn this off? I can start a render using F9 when the view port is highlighted, but otherwise the Maya render view is rather integral, especially when using two monitors. If the VFB had a button to start a render (and specify which camera to render from), then it wouldn't be as much of an issue, as the only other merit that the Maya RV has is that one can quickly scrub between saved renders. Hiding the Maya RV seems like something that should be a toggle, so users can choose.
Jens
Jens
