constant material [standalone]
  • constant material [standalone]
    Hi everyone!
    Is this the right place for questions related to standalone?
    What's the preferred way to create a constant material, for plates, projections, etc?
    A BRDFLight, then MtlWrapper to disable GI?
    Thanks
    Michael
    i don't really understand what you want, but surface shader is supported...
    www.mirage-cg.com
      To clarify, I want a material which isn't affected by lighting.
      I assumed that using the BRDFLight for this would be inefficient , but I just saw the implementation in the sdk samples and it is what I'm after, a simple 'constant brdf'.
        Like you guessed, you need to use BRDFLight for this.
