Render Element - Ambient occlusion
  • Render Element - Ambient occlusion
    I have been testing the vrayRE_Extra_Tex with Vraydirt connected to it.
    However, the dirt node looks at normals. When doing a AO pass, I usually use the Vray Mtl 2sided to avoid this problem.
    But with the vrayRE_Extra_Tex, how can I do this?
    Also is there a way to connect a material to the vrayRE_Extra_Tex?
    thanks.
    yannick
    Portfolio: http://www.cgifocus.co.uk
    I'll add to this question. In older versions of vray, a thin surface would render double-sided, and AO/dirt would look fine. Newer versions have stopped that, and the backside renders black. Why? Can we go back to the old way?
      Any suggestion/answer?
        I'm looking into it (probably will add a "double-sided" option to VRayDirt); there is no way to connect a material to the VRayExtraTex element though.
          Thank you Vlado.
          I think I saw that on the 3ds max side, but could we get a VrayExtramaterial render element to connect another material?
            No, there is no material in 3ds Max either, as this is very complicated to implement. You can kind of get a similar effect using a VRayBlendMtl material - then you can use a VRayMtlSelect element to store each of the components of the blend material into its own layer.
              I'll give this a try.
              Thanks.
