maintaining Vray builds with workstations and the render frarm?
  • #76
    Heya
    Right I'm trying to set up our farm at work to work this way...
    I used this guide...
    http://fredrikaverpil.tumblr.com/post/17727016787
    And I sort of run in some interesting questions...
    1. If I want to use Deadline to render do I just link my Deadline Plugin directory to point to that server shared folder and thats all ?
    2. How do I deal with Phoenix FD plugin ? I want to use its volumetric cloud shader to speed up renders. Should I put it to the folder with the rest of vray on server or localy on machine ?
    I think thats all that bugs me atm...
    Thanks, bye.
    • #77
      For Phoenix FD, we installed it in one central/server location and have it loaded using environment variables. Works like a charm.
      Best Regards,
      Fredrik
      • #78
        So all you have to do on render node is to set environment variables to look at server and in deadline to use server location vray.exe humh... k thanks.
        • #79
          I'm having difficulties getting a central installation of V-Ray for Maya (nightly build 23606) to work with Maya 2014 Extension 1 on CentOS 6.4.
          I'm setting the following environment variables (please note partial python code):
          Code:
          os.environ['MAYA_RENDER_DESC_PATH'] = volPipeline + vrayBaseLocation + buildName + '/maya_root/bin/rendererDesc'
          os.environ['VRAY_FOR_MAYA' + buildMayaVersion + '_MAIN_x64'] = volPipeline + vrayBaseLocation + buildName + '/maya_vray'
          os.environ['VRAY_FOR_MAYA' + buildMayaVersion + '_PLUGINS_x64'] = volPipeline + vrayBaseLocation + buildName + '/maya_vray/vrayplugins'
          os.environ['VRAY_AUTH_CLIENT_FILE_PATH'] = volPipeline + vrayLicense
          os.environ['MAYA_PLUG_IN_PATH'] += ':' + volPipeline + vrayBaseLocation + buildName + '/maya_vray/plug-ins'
          os.environ['MAYA_SCRIPT_PATH'] += ':' + volPipeline + vrayBaseLocation + buildName + '/maya_vray/scripts'
          os.environ['XBMLANGPATH'] = volPipeline + vrayBaseLocation + buildName + '/maya_vray/icons/%B' + ':' + volPipeline + vrayBaseLocation + buildName + '/maya_vray/icons/'
          os.environ['VRAY_PATH'] = volPipeline + vrayBaseLocation + buildName + '/maya_vray/bin'
          os.environ['VRAY_TOOLS_MAYA' + buildMayaVersion + '_x64'] = volPipeline + vrayBaseLocation + buildName + '/vray/bin'
          os.environ['LD_LIBRARY_PATH'] = volPipeline + vrayBaseLocation + buildName + '/maya_root/lib'
          os.environ['PATH'] += ':' + volPipeline + vrayBaseLocation + buildName + '/maya_root/lib'
          However, there seems to be something missing, because this is what I get when I test render:
          Code:
          Starting "/usr/autodesk/maya2014-x64/bin/maya"
          mental ray for Maya 2014
          // Mental ray for Maya: using startup file /usr/autodesk/mentalrayForMaya2014//maya.rayrc.
          mental ray for Maya: setup
          mental ray for Maya: initialize
          mental ray: version 3.11.1.12, Aug  6 2013, revision 202006
          mental ray for Maya: register extensions
          // mental ray Node Factory: loaded
          mental ray for Maya: successfully registered
          mental ray for Maya: loading startup file: /usr/autodesk/mentalrayForMaya2014//maya.rayrc
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/AdskShaderSDKWrappers.mi
          // generating Maya nodes...
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/abcimport.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/abcimport.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/architectural.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/architectural.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/base.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/base.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/basehair.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/basehair.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/builtin_bsdf.mi
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/contour.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/contour.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/paint.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/paint.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/physics.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/physics.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/production.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/production.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/ptex.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/ptex.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/subsurface.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/subsurface.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/surfaceSampler.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/surfaceSampler.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/userdata.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/userdata.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/useribl.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/useribl.so
          // parsing /usr/autodesk/mentalrayForMaya2014/shaders/include/xgenMR.mi
          // loading /usr/autodesk/mentalrayForMaya2014/shaders/xgenMR.so
          Error: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 107: Unable to dynamically load : /mnt/pipeline/bin/vray/builds/130917_nightly_v23606_maya2014_linux/maya_vray/plug-ins/vrayformaya.so
          /mnt/pipeline/bin/vray/builds/130917_nightly_v23606_maya2014_linux/maya_vray/plug-ins/vrayformaya.so: failed to map segment from shared object: Operation not permitted
          Error: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 107: /mnt/pipeline/bin/vray/builds/130917_nightly_v23606_maya2014_linux/maya_vray/plug-ins/vrayformaya.so: failed to map segment from shared object: Operation not permitted (vrayformaya)
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 176: Unrecognized node type 'VRayPlane'; preserving node information during this session.
          Error: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 180: setAttr: Too much data was provided. The last 1 elements were not used.
          Error: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 181: setAttr: Too much data was provided. The last 1 elements were not used.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 185: Unrecognized node type 'VRaySunTarget'; preserving node information during this session.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 187: Unrecognized node type 'VRayGeoSun'; preserving node information during this session.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 196: Unrecognized node type 'VRaySunShape'; preserving node information during this session.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 342: Unrecognized node type 'VRayPlane'; preserving node information during this session.
          Error: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 346: setAttr: Too much data was provided. The last 1 elements were not used.
          Error: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 347: setAttr: Too much data was provided. The last 1 elements were not used.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 586: Unrecognized node type 'VRaySettingsNode'; preserving node information during this session.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 642: Unrecognized node type 'VRaySky'; preserving node information during this session.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 655: Unrecognized node type 'VRayRenderElement'; preserving node information during this session.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 661: Unrecognized node type 'VRayRenderElement'; preserving node information during this session.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 954: 'miDefaultOptions.message' is already connected to 'mentalrayItemsList.options'.
          Warning: file: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma line 955: 'miDefaultFramebuffer.message' is already connected to 'mentalrayItemsList.framebuffers'.
          File read in 2 seconds.
          Warning: line 1: Errors have occurred while reading this scene that may result in data loss.
          Result: /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma
          Error: file: /usr/autodesk/maya2014-x64/scripts/others/mayaBatchRenderProcedure.mel line 312: The renderer vray is not registered yet.
          Error: file: /tmp/ASTMPmfhe2J.mel line 29: Scene /mnt/prod/RnD/fredrik/012-maya/002-maya/maya/scenes/ren/tractor.ma failed to render.
          // Maya exited with status 210
          Any idea what I'm missing?
          Best Regards,
          Fredrik
          • #80
            Maybe you don't have sufficient rights for execution of the file vrayformaya.so? At least the error message hints for that.
            • #81
              Ah, that was it!
              Best Regards,
              Fredrik
              • #82
                If anybody here wants to upgrade to Maya 2014 Extension, maybe you should wait.
                Autodesk confirmed that BlendShape does not work correctly on Maya 2014 Extension :
                http://forums.cgsociety.org/showthre...2&page=9&pp=15
                http://forums.autodesk.com/t5/Autode...n/td-p/4434417
