What compensates the Sampler Info ?
  • What compensates the Sampler Info ?
    which vray node really compensates the maya sampler info ?
    I am aware of the Vray Fresnel, but I would like to use the FacingRatio for the U and V coord.
    So far I wasn't able to achieve the same effect when using the vray fresnel.
    thx for every little info !
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    Can you explain a bit?
      Originally posted by bernhard View Post
      Sampler Info is working...
      Just connect the facing ratio of thr Sampler Info to the V of your ramp, and all is done.
      www.deex.info
        ok.. here we go with an example.
        A piece of very thin cloth which has some kind of transparency. Let's wrap the cloth over a cylinder (2 different objects, the cloth and the cylinder).
        Now, when you look straight to the cloth/cylinder - basically facing the front side - it gives you more transparency as on the sides.
        To get this effect I use the Sampler Info Node connected with a ramp which works fine.
        I was wondering if I could achieve the same effect when using the Vray Fresnel node ?
        Or any other Vray based node ?
        So far, I couldn't achieve the same effect with the Vray Fresnel node.
        Thx for all your comments and thoughts !
          Hmm, why don't just use the samplerInfo node then?
          Other than that you could use the FalloffTex from the "Create texture from v-ray plugin". Same parameters as in 3dsmax.
            I don't want to use the sampler info node because when I use it in a vraystd material, which is the base shader inside the vrayblend... it's messing up the final output.
            I couldn't find out what's really wrong yet... so I thought maybe we do have the same possibility with a vray-built node.
            I tried the FalloffTex, and to drive the falloff I want to achieve I was setting it to type 1, which I guess is P/P and Type 2 should be Fresnel.
            Unfortunately, I can't drive the FalloffTex the same way like the sampler info and a ramp.
            any ideas on that ?
            thx a lot
              Can you get me a scene which has a problem with the samplerInfo node?
